  • Replies 212
Wow its shaping up for a decent turnout. Lets hope the weather is nice.
Updated List:
EnricoP me
MadGT4
9krpm
MattR
Pawley
Miss Nismo
GFXman
Cyrius
Maxx
Cheeky32
Munro
Boostd
nismostu
Guys Location??? V-max hehe? Or somethin similar to the silvia cruise? Anyway its open to anyone. Or someone can just decide for everyone else. The final decesion will be PM'd so that u know who cant find us!
