sup guyz selling
r33 gts-t 95model s1.5 AUTO car black
Stock everything besides pod
71,000 kms on car
car has been hit on the corner drive side so only 3,500 for car to be fixed but selling it whole less hassles for me
welcome to inspect car
engine and gear in very good health
4,500 for whole car
stock internals
pod filter
stock exaust
stock rims
everything intact interrior dash
sterring wheel with airbag still in place
working well
Sad to get rid of the car but only choice at the moment need to move on
dont have the cash money to fix the car and so on .
Contact : 0401275368
Located : Melbourne / South eastern Suburbs / Clayton
Pics can be posted if intrested
Edited by R33TURB0
https://www.sau.com.au/forums/topic/228928-selling-r33-gts-t-s15-95-model-4500/
damaged its a $3,500 fix but i dont have the funds to fix it so im just selling it engine n gear in very good health
and compression test or any inspection is welcome
sup guyz selling
71,000 kms on car
4,000for whole car Price Drop From 4,500 Now $4,000 NO QUESTION ASKEDD OUT THE DOOR
stock internals
pod filter
stock exaust
stock rims
working well
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
