Hey guys
Ok, some of the Tuned WA girls thought it would be a good idea to have a gold coin donation cruise to raise money for our display for POWERCRUISE.
The cruise will be held on the Sunday 14th of September at 1pm at City West. I have already written the map but still have to run it through and make sure theres not too many hot spots lol.
Hope to see lots of you there.
Thanks
Dani
TunedWa Cruise Co-ordinator
Edited by Angr33_Sparcorella
https://www.sau.com.au/forums/topic/230796-tunedwa-gold-coin-donation-cruise/
  • 3 weeks later...
