just went to my kids school show and as i was pulling into the car park my clutch peddle went to the floor. have had a look and i have split the clutch hose on the soft hose about a 1cm from the slave cylinder. my car is booked into the panelbeaters tomorrow afternoon so i need to find a replacement line tomorrow morning so i can fit it to get it to the panelbeaters ;) . can anyone help or point me in the right direction.
Cheers
Eric
https://www.sau.com.au/forums/topic/233647-helpppp/
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
