- Sweet And Simple R33 ! - Pics And Couple Youtube Clips...
Heya all,
Just thought i'd finally get off my bum and post some pics of my ride.
Plus i just bought a new digi camera ( Canon 10mp baby ! ) and just testing and playing around with it.
Had this car for around lil over 6 months now and bought it completely stock, Just tried to keep it sweet and simple. Steer away from the rice, and going with a JDM look ( low and tough ).
R33 95' GTS25t Type M
- Rb25det
- Apexi SAFC II ( tunes by DynoTunz )
- Apexi intake w/ home made heat shield
- Apexi N1 full zorst'
- HKS new design SSQV blow off valve
- Greddy front mount
- Turbosmart Tee @ 10psi
- Custom Catch Can
- JDM Concept reservoir socks !!! WOAH !
- Tein Coilovers ( on lowest setting )
- Cusco Strut brace
- Carbon Fibre gearknob / Autometer boost gauge / Apexi auto timer
- Rare Type M Grill ( well i dont see many around , ebay is the bomb ! )
- Potenza Re001 ( these are the shizzle ! )
- Top fuel sticker !!!! ( Adds 10kw @ the wheels for real ! ) :cool:
- Enkei RS evo II 16"( not on atm , no tread , Old school !!! )
- Dancing Drift Monkey FTW !!! ( solar power .. green peace dood ! ) :down:
Pics:
Youtube clips:
Just bought and install a new design HKS SSQV ( thanks to Steve ) ...
Just a quick strap, down a private road. No speeding on public roads people ! ( before HKS SSQV fitted )
Comments plezz...
Edited by lilhaulerz
  • 3 weeks later...
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
