Item:Greddy Damper Control
Age:Brand New
Condition:Brand New
Price:$300 which includes the spacer kit delivery extra
To Fit:Any car with Greddy type-s (What car)
Contact:PM or post here
Comments:
Sells on Nengun for AUD$580 delivered without the spacer kit which is required to clear the bonnets on certain models
http://www.nengun.com/trust-greddy/remote-control-kit
Came with my coilover but decided not to install it.
https://www.sau.com.au/forums/topic/237341-greddy-damper-controller/
Pictures:
More info on it
GReddy Performance Products is proud to introduce the Performance Damper Remote Controller (P-DRC) that enables users to electronically adjust suspension settings 32 ways from the driver's compartment.
What it Does:
The Damper Remote Controller enables users of GReddy Type-S suspension kits full control of suspension adjustments via an electronic interface inside the driver's compartment. Key features include:
* 32-way suspension adjustment capability via electronic interface
* Ability to independently control front and rear shock damping settings
* Saves up to five (5) user-defined suspension-setting combinations-have multiple track settings ready with the press of a button!
* Security feature prohibits anyone without pass code from making adjustments to your live setting or saved settings
* Proprietary software monitors system for errors and alerts user of potential issues with trouble codes
How it Works:
The P-DRC uses a three-button interface to make adjustments: one button each for mode and function selection, and a rotary knob for scrolling. Simply select your mode using the mode button, adjust settings via the rotary knob and confirm your adjustments using the select button. Feedback is provided on a digital LED screen.
Available For:
Application-specific Performance Damper Remote Controllers are available for Subaru WRX/STi, Mazda RX7/RX8, Mitsubishi EVO, Infiniti G35, Nissan 240SX/350Z, Lexus IS300 and Toyota Corolla (AE86). GReddy has universal systems and adapting hardware for custom set ups, please contact GReddy at (949) 588-8300.
General Specs:
Head Unit Dims: 22mm x 80mm x 84mm
Controller Dims: 22mm x 80mm x 74mm
Motor Dims: 45mm x 45mm x 35 mm
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
