Krispy Kreme/ Maccas Cruise To W'gong 2nd Attempt :) 15th November
  • Replies 131
ah come on bored33!!!!!!!!!!!!!!! last time we headed down to the gong it was raining but it actaullay made the drive better especailly at Mt Keira. Ya dont get wet in your car........
coolness thanks jeff. and as i prev said to all else, i will be somewhere around (more than likely in maccas knowing me......) just look out for the pink callipers underneath the 33stockies ( :banana: )
ha, nothing wrong wit a bit of window down in rain... but trust me. the rain makes this drive better. the trip up to mt keira last time was surreal last time with the fog up the mountians
im waiting on my mate to send me the pics so that i can upload them. There are a couple of good ones. Not too many tho lol
adrian should hurry up haha.. i wanna see them pics LOL
