Nissan Skyline r33 95 gtst:
Cluster has done 150k, engine,gearbox,turbo all done 80k:
Manual:
White:
Sale, vic:
Rego is till july 18 2009
RWC supplied? Yes
Currently registered? Yes
13k ono:
Contact: Alex on 0419175496
Comments / Modifications:
drift wing
veilside sideskirts and rear bar
king springs coilovers
Turbo smart bov
hks airpod filter
nismo strut bar
pioneer sound system
custom white interior (only in the cluster to manual shifter)
600*300*76 intercooler
oil catch can
18'' rims avs White
plus more.
The car is beautiful and needs no work, its very reliable and never have problems with it.
come have an inspection if you want.
there is more done to it, so give me a call if your interested in it.
thanks alex
ps photos are a little old but there has been no damge done to the car since it was taken.
will swap for a car that non turbo? :cheers:
Images:
https://www.sau.com.au/forums/topic/241300-white-r33-for-sale-manual-turbo/
  • 1 year later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
