  • Replies 89
were not that bad haha :banana: na we r pretty controlling and jelous ppl lmao but hey it shows we care??? gota count for somthing haha
yer dates have changed, its on the 14th december now .
i got rego on the 24th of november :P
lol
hey guys, im thinking of organising a cruise to newcastle forshore, just seeing how many ppl would be intrested in going.
im at tuggerah so mayb for the central coast ppl we can meet somewere round here.
itll be held on the 15th of november, ( saturday )
thanks :P
the cruise is on the 14th of december???
so which one is it??????
Edited by SNOQPY
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
