  • Replies 89
If I'm not working you can count me in.. havent been on a cruise yet and keen to pop the cherry.. :ph34r:
what time are you meeting and the twin caltex's?
Corey,
EDIT: better wash the line then too.
Edited by sIIgtst
were not that bad haha :banana: na we r pretty controlling and jelous ppl lmao but hey it shows we care??? gota count for somthing haha
yer dates have changed, its on the 14th december now .
i got rego on the 24th of november :(
lol
I was sitting on the couch next to her, this girl on TV came on, I go, wow she's hot!!!
She grabbed the magazine that she was reading, rolled it up and banged it over my head several times!! Showing she cares :(
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
