Hi Crew
What a way to end the year with a blast around the famous ORAN PARK south circuit. If you have never been around ORAN PARK this is an opportunity not to be missed. There will be plenty of quality driver trainers such as Luffy, myself (Boz lol), Benny Porter (recently crowned National Formula Vee Champion for the 2nd year running) and more Instructors depending on numbers.
With a SPECIAL price of $265.00, this is a bargain. Luffys TRACK ATTACKS normally retail for $325.00 as some of you are well aware :smile:
This day is definitely happening as we have already paid for the track. If you organise it through this thread I think I will be able to get another couple of dollars off.
So boys and girls let me know if you are in for day :O
  • Replies 61
There is perhaps something happening on the north Circuit being a Saturday.
You twist one arm John and ill grab the other. Surely he'd give up before we break him in half.
Have you mentioned this day to John Pelican??
I spoke with him Friday and he was rather "interested" in having a day out with us soon.
His got some catching up to do at oran park though.
So I think he'd be more than up for it.
I just off the phone with old mate Jason, he may be in as well...
Edited by Risking
Just spoke to him, he is keen and will put it on his site. He is at Eastern Creek all this weekend running the Zed.
He also just told me superlap is all go for Oran GP 2009 in March woohoo
Yeah I heard all about that on Friday too. So he did enter the nationals. Will be interesting to see/hear how is new suspension handles the quicker circuit, its kinda, sorta similar to what Ive done with the new GTR.
Jerad Manion is out there in his EVO this weekend too. Ill mention the Oran park day to him on Monday as I think he'd be all for it as well.
Hmmm sounds like a good idea to me. Its been sitting for some time thats for sure.
You could always buy it and that way I can drive it when mines broke!
Its even still got the right name on the quarter window mate.....
It should be out at the creek this weekend getting some exposure.
Edited by Risking
I will be bringing my car aswell with Brad (risking) I would love to have you in my car Boz..need all the help I can get :)
Will mention it to a few of the guys that did Dutton with me as well as we all need the practice lol!!
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
