Hey all,
Times come to sell the GTST, recently purchased a GTR :blink: so I wont be needing this anymore. Im the second owner in Australia, the previous owner was a middle aged professional.
I am open to swaps with money my way for a cheaper Non Turbo vechile. Must be Auto and rego'd in NSW.
R33 S1 GTS-T 1994
103,xxxkm
5 speed Manual
Tinted rear windows
Sony Headunit
Alpine Type R speakers
Doors have been Dynamat'd
N1 water pump
N1 oil pump
*I was told when I bought it, it has a mild ported head, multi angle valve job, regrind cams, but I cannot confirm this as I have never opened the motor.
Always serviced regualrly either by myself (oils, all filters, sparks etc) or at a professional workshop for major services
Redline oil in diff and gearbox
100,000km Major service done by UAS mid last year
UAS heavy duty clutch - replaced mid last year
Daugther board ECU
3" dump -> hi-flow cat -> Kakimoto Jasma approved exhaust - very quiet down low
FMIC with custom piping
K&N filter with custom metal airbox
AVC-R tuned to 8PSI and 12PSI (installed by CRD)
HKS Turbo Timer
Whiteline bushes replace early last year
Whiteline strut bar
040 fuel pump intank
Always run on Synergy 8000 (mobil purple)
Slotted DBA rotors front and rear
Atmo SSQV can provide stock BOV for legalities
Just under 1 Years rego (expires 24th October 09)
Alarms + immobiliers (will only disclose to buyer)
Series 2 front end (not put on from accident damage have pics to prove)
Top Secret Front bar (usual scrapes from gutters), 400R side skirts and rear bar, GTR spoiler
Custom painted dash, (professionally done)
Momo Racing steering wheel
Gun Metal Grey
Down side, there is a tear in the carpet on the drivers side, but I will provide new carpet with the sale.
Can either come with stock rims or 18" Racing Hart's with decent rubber depending on nego price. Rims in picture do not come with the sale.
Have other spare parts I can include with the sale if desired. Including a Tommy Kiara series 2 front bar.
Price is $13,500.00 neg.
Car is either located in Sutherland or I can arrange a CBD inspection.
Cheers,
Johno
0401466244
I will post up more recent pics and engine pay shots over the weekend.
$12,500ono
Forgot to mention, it has Braided brake & Clutch lines all of which are ADR approved.
Serious buyers only, please check with your wife before you make an offer lol.
Cheers,
  • 2 months later...
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
