Well... To be honest its only half done. The main section isnt painted, and the rest was sanded down too much so its too rough. But its coming out again and being redone perfectly. I'll provide pics of it before, now, and after when its all done
https://www.sau.com.au/forums/topic/246270-my-new-r33/#findComment-4282883
