Milage:68,000 on the car and 8000kms on the engine,turbo etc
Transmission: Manual
Colour: Midnight Purple
Currently registered? yes
Price: $21,000
Contact: 0420 650 467
Images: yes
Item: R33 skyline
Item Condition: as new
Reason for Selling: ready for something else
Extra Info: as follows;
Engine + Drivetrain;
-The car is currently flowing 464.8 atw on 18psi boost with the rev limiter set at an early 7200rpm (this motor has been built to rev to 8500-9000 frequantly). This is only a light tune and far from the cars potential.
-The car has had a complete overhaul by a well respected shop on the Sunshine Coast (Chapmans)
-Oversized Ceramic coated JE forged pistons
-Gtr eagle rods
-re-bored block
-high flowed head
-Fuellab fuel regulator with gauge
-Gtr intake manifold (refreshed with the buterfly's all re-adjusted)
-Garret gt3076R turbo (8000km's)
-Complete ARP stud kit throughout
-steam pipe low mount manifold
-38mm external wastgate
-screamer pipe
-Gtr fuel rail & Injectors
-Bosch 044 intank fuel pump with upgraded wiring
-HKS triple layer stainless steel Head gasket
-3 bar Haltech map sensor
-Wolf 3d engine management (with hand set)
-Custom oil catch can
-remote oil filter
-Exedy heavy duty clutch (8000km's)
-nismo short shifter
-Redline gearbox oil
-minispooled diff
-lightned flywheel
-16 row oil cooler
-Nismo dump pipe
-kakimoto exhaust right through
-fmic with mist squirters
-turbo smart bov.
-New coil packs
-New water pump
-New oil pump
-New main bearings
-New conrod bearing set
-New timing belt
-New cam sensor
-New crankshaft oil seal,oil pump gasket, tensioner bearin, idoler bearing, mainifold gasket, rocket cover gasket, throttle body gasket , and all the other gaskets you would expact to replace when completley pulling a motor down!!!
-All new heater hoses
-New battery
Suspension/brakes;
-Apexi coilovers with adjustable dampner
-brand new brake pads all round
-brand new rotors all round
-Custom fixed rack in the rear with adjustable rods
Body/interior;
-Painted by the DMD image in custom version of the Gtr Midnight purple
-Nice body kit not over done SEE PICS!
-30 psi boost gauge
-Wolf 3d hand set
-Oil pressure gauge
-Pro comp shift light
-jap turbo timer
-Double din Addzest headunit
-Focal 6inch speakers
Wheels/Tyres;
-17 inch dished Gewalt wheels with gold centre
-Toyo R888 street slicks on the rear
-New tyres on the front
Extra info;
-Car will be sold with 11 months QLD rego
-I am not really after swaps but if the right one comes along i will consider. PLEASE DO NOT offer me rediculous swaps!!!
-This is one quick car and has been built to flow 550atw reliably, it is a tuff streater that drives like a stock one and can be driven daily (the tuning speaks for its-self).
-This car has no problems breaking out in 1st, 2nd, 3rd & even 4th and probably should not be purchased by anyone who doesnt has some kind of experince behind a powerful car. The first person to come for a drive in this car will be hooked (no time wasters welcome!!!).
-I am sure i will regreat selling this car when it has gone, as a lot of time has gone into it. Anyone who has built a tuff car can respect that there are alot of hurdles along the way and it doesn't happen overnight. The person who does get this car will not have to go through this process and be able to jump right in an turn the key!
Massive thanks to the people who have helped out with this car!
Contact Details: 0420 650 467
https://www.sau.com.au/forums/topic/247554-big-horsepower-r33/
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
