FOR SALE:
2003 Titanium Grey Mazda RX8 with red/black leather trim
113,00kms
9 months Rego
Log Books, Receipts, New Slotted Front brake rotors and New Brake Pads, New NGK Spark Plugs, Just Serviced, All genuine mazda parts
In the process of buying a house so I need the cash for the deposit
Selling very cheap, never had an issue with the car, very well looked after
Will not Dissapoint
All inspections welcome
PM me or contact me on 0414 096 594
Thanks, Pete
is this car turbo? as im looking to get one and im on my P's
also this is the cheapest rx8 i have ever seen!
rx8's are non turbo, p plater legal
selling cheap as i need quick sale for my new home
  • 4 weeks later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
