FOR SALE:
2003 Titanium Grey Mazda RX8 with red/black leather trim
113,00kms
9 months Rego
Log Books, Receipts, New Slotted Front brake rotors and New Brake Pads, New NGK Spark Plugs, Just Serviced, All genuine mazda parts
In the process of buying a house so I need the cash for the deposit
Selling very cheap, never had an issue with the car, very well looked after
Will not Dissapoint
All inspections welcome
PM me or contact me on 0414 096 594
Thanks, Pete
is this car turbo? as im looking to get one and im on my P's
also this is the cheapest rx8 i have ever seen!
rx8's are non turbo, p plater legal
selling cheap as i need quick sale for my new home
  • 4 weeks later...
