I have a Brand spanking new BEE R rev limiter. It comes with all the genuine connections it came with form japan. I've had it sitting in my room for the past 3 years. Never ended up using it.
Asking $350ono.
https://www.sau.com.au/forums/topic/252104-beer-rev-limiter-spanking-new/
I still have it.. But its Sold and Pending payment form HR31GTS-X. But I seem to have lost communication with Him... He has not replied since last Thrusday.
If sale falls threw, DRIFTER is next in line...
