Hi,
This is for Darwin NT people however I am impartial to interstate inquiries.
Details are as follows:
1996 Galant VR4, Metallic Purple (Trigger Mauve)
2.5L V6 Twin Turbo 4WD
Active Yaw Control
86,000km
Climate control, Power everything
Mods:
K&N Rampod air filter
2.5" Al hard piping kit
600x300x76 FMIC
Turbosmart Type 1 BOV
Twin 2.5" SS dump pipes to 3" Hiflow exhaust system
Haltech Interceptor ECU tuning: boost, ignition timing & fuel
Evo 8 Enkei rims
Pillar mounted pod B&M high vis boost gauge
Top gun leads, Iridium plugs
Performance:
Power - 218awkw (estimated)
Boost - 14psi
0-100 4.9sec
0-400 - 13.3@101m/h
Overall this is a very well looked after vehicle with servicing done regularly, oil changes vigilantly done every 4000km, Auto trans done every 10,000km. Extremely easy to drive and handles beautifully.
Asking: $20,500 neg (which means make me an offer!)
Ph: 0415 458 465
[email protected]
Thanks
Josh
A little vid I made of Hidden Valley Drags:
http://au.youtube.com/watch?v=tocjo1sGMsg
https://www.sau.com.au/forums/topic/252826-96-vr4-galant-1331013-darwin-nt/
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
