this may be a very silly question but i am going to ask away any ways.... when is it time to get a engine rebuild or a new motor all together like how many kms? down the road my R34 is pushing 264,000 kms Dam that Melbourne trip and back to Perth from Geraldton was fun........ haha :D
I just put in New Spark Plugs and coil pack and my nasty Busted WRX Sounding motor is sounding way better now and not a WARNING light to be seen :):P:cool::D:geek:
So the question is how many kms before a new motor is needed?
Edited by DiNoBoNeS
https://www.sau.com.au/forums/topic/255010-been-thinking/
until it dies
depends how its been looked after
better = longer
no real number, lots of taxis run around with 600,000kms+
but they leave there cars on all the time and service very often
Tops thanks mate i try and look after her and do the right things i work as a photographer and i leave it running when i am shooting I am only with the guy/gal for like 4 minutes so no need to turn it off and on all the dam time... just was thinking if there was a kms number to do it or if it was the case of wait to it go hehe she is running strong and i do not think it will be for a while i can not wait for 300,000kms.
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4400195
when it gets low compression, or has a fair bit of leakage.
leaving a car idling is not ideal either, the fuel isn't burnt correctly, and runs down the side of the bore, washing off the oil with it, and contaminating the oil.
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4400198
your car will get hot if its just sitting there idling
best to just let it run for a minute or 2 then turn it off
rebuild it when it pops...
your car gets hot just idleing?
i dare say keeping it running > on and off all the time
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4400429
yeh, if you had a digital temp gauge (i use my pfc hand controller) you would see
if your not driving and having air blowing through your cooler etc your car actually heats up at idle
not much but for example
my car usually operates at around 80-82 degrees
i sat in the car park and ate maccas with the air con on one hot day and the temp got up to 105 degrees and went back down after i started driving again
the day and air con did play a part so the temp rise isnt usually as big
best to turn it off..
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4400446
yep.. the only time we realised we hadn't plugged my mates thermo fans back in, was when we pulled into the macca's drive though, and it started to get hot.
most fans will stop, or slow down when the car is moving.
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4400449
That's pretty hot dude.. highest I've ever seen on my 30 is 104deg and that was after a couple of big smokey burnouts on a 40deg day!
FYI boiling point is around 110-115deg.
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4400565
If your car is getting hotter when its idling then something is stuffed. When temps start to rise a bit the fan is suppose to kick in to pull air through and keep temps steady.
My temps don't rise one bit no matter if I'm moving or not. Sits on 73 deg all the time (PFC hand controller and new watter temp sensor). Car also runs an N1 watter pump which doesn't flow as much watter at idle as a normal watter pump and still no issues at all
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4400819
95% of engine wear happens when the engine is cold. Thats why taxis engines start to go at 1,000,000kms, and trucks get their engines rebuilt when they clock back to 0 only because they can. I've worked on trucks with over 500,000kms with engines that are fine, and cars that have bearing noise at just over 200,00kms.
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4401253
thats only if you have thermo fans on your car
belt driven fans are constantly working and engine temp SHOULD co up slightly if not moving due to less air movement through the core
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4402123
(feel free to correct me people)
Oil is a major factor in engine wear.
your engine would run dry for 2 seconds before the cold oil is pumped up to the valves and while the oil is cold its not flowing easily.
I've seen inventions for pre-heating oil sumps before starting, and i'm sure someone will have invented a oil primer.
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4403775
actually the fans on RB's are clutched, they apparently stop moving at higher speeds.
but yes, they are constantly spinning at idle
They don't stop spinning at high rpm, the clutch is there so that the fan isn't spinning at full engine speed at high rpm.
As for oiling, there are products out there that retain oil pressure in a container so that the instant you flick the key, it squirts the pressurised oil through the system immediately prior to startup.
https://www.sau.com.au/forums/topic/255010-been-thinking/#findComment-4404321
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
