EDIT: Just realized the upload onto youtube has compressed it so much you can hardly see anything. Also it seems like the colours are lost in the stars..
This sucks lol.. Anyone know where else i can upload the video? Or exactly what settings to create the video? As in frames per second.. What format etc..
Just a mini timelapse video i have created.
Theres about 100 or more images used to create this.
No editing was done to any of the images. Just a process of 100 images stacked i guess. Its sorta how i do stair trails..
The earth silently rotates while you sleep:
http://au.youtube.com/watch?v=WR2dXt8EY_8
Hope you like it.
Edited by siddr20
https://www.sau.com.au/forums/topic/255312-my-mini-timelapse-movie/
Isn't it possible to create a video like this with a whole recorded video while it's night?
I think it would be a more fluent passage if you create another video with a spool part of your whole recording.
But whatever i really like your video :P
You mean actually taking a video from a video recorder?
I dont think it will come out nicely. But then again i dont own a video recorder so i wouldnt know.
Also these pictures are 13 second exposures. So doubt the video recorder could capture all the light in.
Hense why ppl take pictures instead as your slr camera can capture as much light as you intend it to.
so how did you do it? the actual photo taking i mean
was it a manual - press the shutter every few minutes kinda deal?
or do you have some fancy timer that does it automagically
I captured about 100 images or so. Perhaps more (havnt really counted but theres heaps lol).
Each image is a 13 second exposure.
I noticed the stars slowly disappearing away behind the roof and hense why i stopped. Unless i would have left the camera on till the memory card filled up.
The same way you can do star trails. Stacking 100 images or so.
Heres my 1st attempt i did a while back.
what i mean is how did u take the pics?
did you manually press the shutter - wait 13secs - manually press the shutter - wait 13secs - and repeat (another 98 or so times) ??
ie so its a manual process where you sit there taking pic after pic for 20mins or so - correct?
Oh nah nah the shutter release cable was held pressed in. I came back 20 minutes later and turned it off..
If you got a shutter release cable you will know what i mean.
But now you are wondering how does the camera take pictures every 13 seconds or so. Its called burst mode. Use that setting, with release cable and it will keep taking photos till you turn it off.
Yeah i mean a video camcorder(?) i saw a few videos at youtube of timelapses and i thought they were just very fast videos
Like this one:
But all right, thank's for the lesson :(
No worries.. Let me know how you go :D
this is how i went! pretty dodgy but its a proof-of-concept for me!
(was just taken at my back door - so next time i'll go somewhere a bit better and hopefully I'll get something nice)
ps nice and big one just for you :(
Great work for your first attempt :D
Stars looks thin and thats what you want (as in the lines)
Now the next thing to do is to find the southern Polaris. So you get the whole circle look.
But well done on your first attempt.
The software i suggested will help heaps as well ;)
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
