Since I have bought a track-only racecar, I need to sell the Cefiro to get some boring bomb that can tow cars.
I brought the car in from Japan and did the SR conversion before compliance. Ive had the car for around 4-5years
The car has approx 170k on it but the engine has around 100k
#Car
White
electric sunroof
R32 gtst 4pot front brakes and R32 gtst 2pot rear
#Driveline
SR20DET redtop
gt28r turbo
turbo-xs bleed valve
Bar and Plate FMIC
Turbosmart type 3 bov
Pod Filter
3in Turbo-back exhaust with twin tip xforce muffler
40mm alloy radiator with twin thermos
Exedy 9 puck button clutch
Viscous LSD
Cusco catch can
Walbro fuel pump
#Interior
Grey interior
Momo steering wheel
Pioneer CD/MP3 player
#Suspension
Front Strut brace
Cusco adjustable castor rods
Alloy subframe bushes
hicas lock kit
6 Months Rego
$6,500 no offers
Coilovers, rims and S2 taillights not included - all replaced with stock items
This car weighed in at 1220kg just prior to compliance, so they are a lot lighter than they look (especially without the nugget RB motor)
Bad things - One guard is a different colour white (as seen in pics), gearbox has a bit of bearing whine (but shifts perfectly)
Not much interested in trades
https://www.sau.com.au/forums/topic/257731-sr20det-cefiro-6500/
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
