Prices are neg.
here are 4x r33 rims with brand new nexen 16/225/50 rubber. $550 the rims themselves have oxidized streaks in the clear coat. probably from brake fluid from previous owner. pick up. or interstate postage (buyer to pay). can deliver in sydney for $25.
here are 4 mazda eunos rims, no tyres, with the 114 pcd 5stud pattern. they fit the rear but will need spacers to fit the front. pick up. or interstate postage (buyer to pay). can deliver in sydney for $25.
here are 3x 17 235s rubber only 1 is federal 595ss the others are falken 326's. pick up. but can deliver in sydney for $25.
here is a stock r33 gtst exhaust system. minus the dump pipe. pick up. or interstate postage (buyer to pay). can deliver in sydney for $25.
here is a gutted stock cat pipe. more flow :($10 pick up. or buyer pays post.
here are stock r33 gtst front and rear sway bars with rubbers. $80 for both or $50 ea. pick up. or interstate postage (buyer to pay). can deliver in sydney for $25.
here is a series 1 front bar for an r33 gtst. $70 pick up. can deliver in sydney for $25.
here is a LHS fender it needs to be resprayed and pannel beated slightly for the dint and the headlight surround. it would do for a drift car though. the damage is minor. see pics. pick up only.
here is a left over sheet of aluminum mesh.the largest part measures 59cm L x 27.5cm W. the but overall it is 121cm L. pick up only.
here is a left over 4.10m roll of exhaust wrap. $25 pp
here we have 2x universal racing harness's (one red and the other black). with all of the hardware to fit them. i will separate these. $60ea or $100 for the 2. pick up or buyer pays postage.
here we have an r33 gtst s1 manual computer . $100 pick up. or interstate postage (buyer to pay). but can deliver in sydney for $25.
here we have a walbro 341-gss 255lph (with all the mounting gear plugs etc). it has the same internals and ratings as the 342-gss. the only difference being the outlet. the 341 has the outlet on the other side of the inlet. where as the 342 has it straight in line with the inlet. it will not make a difference whatsoever. $120 pick up. or interstate postage (buyer to pay).
here we have a r33 gtst used sard top intake sports induction kit with bolts to mount it. $50 pick up. or interstate postage (buyer to pay).
here we have 2x r33 gtst whiteline subframe split pineapples. these are split so they can be fitted to the upper part of the subframe bush. used to set the car at neutral stance when used with 2 other pineapples. $15 pick up. or interstate postage (buyer to pay).
here we have an r33 gtst stock gear knob and a 2.5" x 3" silicone/rubber intercooler pipe join. $15 for the join. $15 for the knob. pick up. or interstate postage (buyer to pay).
Craig.
04396961454
[email protected]
Edited by Trust33
here are the rest.
here are 2x r33 gtst stock mspec side skirts condition ok. and 1 LHS 400r nismo side skirt in primer still needs prep work. $80 for the mspec's and $40 for the 400r. pick up. or can deliver in sydney for $25.
here is an r33 gtst stock radiator perfect condition. needs to be cleaned and flushed by a pro shop. $40 pick up. or interstate postage (buyer to pay).
here are 2x front r33 gtst HKS hyper D adj height and damper coilovers 1 is fine the other is shagged. the pillow ball shaft has come apart from the main shaft. it made a knocking sounds before i took them out. will need a rebuild. there is a place in QLD that does these and a place in VIC as well. $60 for both. pick up. or interstate postage (buyer to pay).
here is a holden commodore VT washer bottle pump and a one way valve to stop leaks when the pump s not in use. for a DIY intercooler spray kit. $30 delivered.
Craig.
04396961454
[email protected]
Edited by Trust33
$125 pick up or $150 delivered (by me) in syd.
there is another guy interested in it as well. i will give it to him if he still wants it. will msg him about it. if not u r next on the list.
no on the other things u asked about.
Edited by Trust33
wat are the chances we could meetup? i wont be able to make it to ingleburn for a while. ...u go city or anything? can always jus drop by or meet u somewhere wherever u are for that wrap, shoot over a PM
i work at villawood. though i do go places from time to time. other than that there is the post. where are u located? and where are your usual haunts?
throw me a pm!
Edited by Trust33
err...u got an extra digit in ur phone number :S yea villawood would be awesome cos i drive thru there every arvo. i live in liverpool cbd
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
