Macs usually aren't as cheap as most other lappy's but JB HiFi usually do pretty good deals
there's probably other places around, theres an apple shop in the carillion arcade in perth above Hungry Jacks next to Game Traders, but they wouldnt be as cheap as some other third party retailers.
https://www.sau.com.au/forums/topic/260511-imac/#findComment-4469611
i got mine from Graham's said store above ^ 'DigiLife' but i went there the other day and they had closed down or something?
there is another store somewhere else but i'm not sure, Subiaco or something of the like
great prices anyway man, a Mac isn't cheap but you get what you pay for
my advice is to try the Apple Online store and i think if you're a student at certain Uni's you get certain discounts? don't quote me on that one though
Andrew
Edited by hoony
https://www.sau.com.au/forums/topic/260511-imac/#findComment-4469972
went to nextbyte today (apple store) and they want $2000 for a imac with the mid-level screen (i need a decent sized screen for the application im using it for). tis a bit expensive, i remember my mate saying he got his imac for $1500 (this was about 3 years ago).
https://www.sau.com.au/forums/topic/260511-imac/#findComment-4474241
as hoony^ said, buy through Apple themselves as you can get a Student Discount
I got mine a year and a half ago now for around 2.2k down from 2.5k
In the end when they delivered it they didnt even care if I was a student or not, no ID required or anything.
https://www.sau.com.au/forums/topic/260511-imac/#findComment-4474267
Artref in Jollimont.
They are the oldest Apple dealer in Perth and you actually get support as opposed to just an invoice. Price isn't the lowest.
yeah rang my mate today and he mentioned the same place, looks like i will be checkin this joint out and get this show on the road. yyeeewwww :blink:
https://www.sau.com.au/forums/topic/260511-imac/#findComment-4476326
  • 3 weeks later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
