Made a new website image for Tas:
Credit to John for the idea
bahahahaha*takes breath* hahahahhahaahha. Need to add some rocker stoppers :ninja:
oh i see how it is,
how about you go get some coilovers for your 31
OOOOOOOOOOOOOOOOOOOOHHH thats right - no coilovers for 31s.. too old
:D
S13 coilovers + Cusco 31 camber tops = 31 coil overs...
P.S. Got a little worried searching for "Box" in google images at work. Turned out OK but, safesearch was on :)
Safesearch ftl lol
lol
R31 FTL :)
Look! I found a picture of your 180 at the drags:
Its got a good 40 sec pass in it for sure.
sorry i will say something, im just trying to translate what the pom is saying...
:ninja:
It's alright lots of emos struggle with english. Would it help if everything was in poem form?
what about that epic r31 i found ages ago martin? ima going to try find it againn
I have a really awesome pic of that number 12 GMS car at home as my walpaper, but for the life of me I can't find it again here
Edited by Smity42
my orange is so teh sex
ur just upset that i can pull 10ton bitches while ur car sits on bricks with rust :) more rust then dave!
Fixed.
I think you might have been lead down the garden path there with the size/quantity thing Tas
Edited by GTTG
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
