:ermm:
This is awkward :laugh:
theres the handbrake set up i was talking about tonight also :)
Very nice :(
yeh thats pretty f**king lol hey
ps martin and dan... and even colin
this is 31 done right:
now man up
Makes me moist. No 18s for me though :)
guess you suckers bailed on the wash....queers.
John and I got there but you had already left. Got there are like 10:30ish?? Maybe earlier I can't remember.
na we just stayed at our new location for ages and most of us turned into faggots at 10 oclock and bailed.
Fixed for you.
new location hey... sounds secretive...
I like it :)
its sexual ;)
:P
I can smell it :(
Smells like....victory.
its sexual :)
No its not its shit :(
This pintara makes my 4yr old willy pop up
Wheels dont quite fill the flares. Needs more offset
Qantas club Darwin post
They serving free piss yet?
Makes me moist. No 18s for me though :P
15x15 is where its at
The gabnr was talking to me on msn about then. He must have gotten there after you left
Smells like dirty ranga pom
P.S. I can't believe all you f*ckers were paying me out for not going to the carwash, then none of you went anyway :P
And sorry to Tacio who was trying to follow me out, I slowed down to let you catch up but you never re-appeared. Hope the immigration police didn't get ya
Touche
QFT
Oh true shit lol. Well sorry Michael. No point in staying though everyone else had bailed and I wasn't even going to wash the car :P
Because it is.....
Also...
I believe I now have a set of 18x9 +14 5Zigen wheels for sale....will start a for sale thread when I get home.
Polished lip...silver 5 spoke. Genuine Rays forged rims.
DAVE:
These are the rims I was talking about. Do you know what they are? Hoping they're not BJ spec...
Look like Enkei NT03+Ms. Could be just a knock off version of them though.
I thought so too, but the NT03 rims are 12 spoke. These are ten... If all else fails, I'll probably get Enkei EDR9s:
wheels first car later :P
This man knows the score! :down:
the boat he buys might have epically awesome wheels on it already
...though they'll probably be rusty
Which is why I'm not buying anything until I have a car to put them on. But I can still plan :P
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
