points are given as i see my SAU sticker :(
Speaking of which, I still need more of those.
Umm... won't have money this week, so next week, when you're rolling dirty in your 180? May I have one of each please? Not sure if I want inside or outside yet.
So it seems nazi quotes in signatures actually works: http://forums.overclockers.com.au/showthread.php?t=833662
And that only took a few days :banana:
Go and submit everyone, tell the gov't we want to be treated like adults!
If this works, there may be hope for unfiltered interwebs yet...
Edited by Smity42
I'm not even really sure what it is that you're doing... or what you're protesting...
Obviously struggle with that reading thing hey? :banana:
What I'm doing is not much :P. Its just a coincidence that the goverment has started this consultation days after I put that quote in my sig (not just here). But I thought it was funny.
What I'm protesting: Essentially, the continued trend of the government to try and squash our rights and freedoms under the guise "Won't somebody think of the children!". The two big examples that p1ss me off being the ones in my sig: No 18+ rating for games (ONE man is blocking this, what kind of democracy is that?) And this fr*ggen rediculous internet filter the federal gov't is still trying to push, despite basically everyone being against it, and the fact its not going to do anything to 'help the kiddies'. Its just the gov't trying to control the one form of media they currently have no control over.
Well summed up by one game developer:
Australia is a country where:
Adults are not considered by their governments to be able to make their own entertainment choices.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
