Yea, RSR and KU36 are slicks wannabes, Hahahaha! The whole street legal slicks is just a market thing. Slicks = RE55 and Toyo888.
Hence the name "semi" slicks dudeman :)
This Thread has come to a grinding halt ever since lunch time :ninja:
Wtf is up wit that ? Everyone ate so much they cant get close enough to there desk to type ?
I ate, did some cleaning, then had a nap... couldn't post while I was sleeping :)
HAH!
You've got nothing on me dude.
I ate, did some cleaning, then had a nap... couldn't post while I was sleeping :ninja:
Ok Ill accept your excuse but whats everyone elses ?
Yea. But I'll like to know how long those KU31s and KU36 last. My colleague that drives an FD reckon the KU36 he's got are only good for around 20000km-25000km. I wonder if he bother doing any wheel swapping...
just remember an FD is 400kgs lighter than your car... that'll affect your tyre life.
They aren't proper semi slicks dude. The ones brandon listed aren't slicks, they are semi slicks with propoer R compound
RS-Rs, KU36s, are just really soft road tyres
    • Hi all, I’ve just finished fitting the timing belt on my RB25, following the standard procedure: rotate the crank twice, release the tensioner, then tighten it down. The belt feels tight, and you can see that clearly in the picture below I’ve heard some people say it’s actually better for the belt to be slightly loose rather than too tight, as excessive tension can lead to snapping. So that’s in the back of my mind. What I’m seeing is this:  • At idle, the belt looks fine.  • But when cranking and especially when revving (around 3–4,000 RPM), there’s a momentary flap/flex or flicker in the belt, which I’ve tried to capture in the video. So my question is — based on what you see, is this slight belt movement something you’d consider normal, or am I just being OCD? Could this amount of movement cause sync issues? Or is it just a harmless bit of flex under load?   from what I know belt flap and flex is expected when crank spins up and pull cam with it Would appreciate any thoughts or similar experiences.     IMG_7656.mov IMG_7657.mov
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
