Dan - explanations for both because I'm not sure what part you were asking about
In other news however, I am making a grated cheese and scrambled egg sandwhich.
yum... toasted ?
no! toasting it would cause the ketchup matrix to destabilize!
if only I had tabasco sauce... tabasco sauce would have turned this sandwhich into a winburger!
the short version.
Sarina Russo said "yes, we're a job network member, and can help you look for jobs. But first you have to spend 2 weeks doing one of the following things: Work for the dole, course in admin, course in retail, course in customer contact.
I figured I knew the most about customer contact and figured I may as well get a bit of paper to say I knew how to do to chuck on the resume. Seemed more appropriate than retail or admin. Also decided I'd get more out of that, than work for the dole. Which would give me skills in unpacking boxes and working with ex cons.
So I sign up for it. Then all of a sudden it's five weeks and it's soooooooo mind numbing.
The really annoying part is I got told there were limited places in the course, and that only the best applicants would make it in. If they're only going to accept the best... why is it so elementary?!
Edited by Isola
on a slight side note, any of you guys going/ or coming from nerang any time this week?
need to pick up a bumper from there, but haven't got time to get out there any time this week.
Damn, Dan took my ute down to the GC yesterday arvo. Shame we didn't see this in time.
Sorry dude, I got no plans to head that way soon.
Morning manging mengz.
Wow........11 hours since last post :O
Hmmm very strange for this bunch of whores :down:
Maybe people actually have stuff to do at work these days?
day 4 of 25 :P
Seriosuly dude? FIVE WEEKS? If it was 2 weeks I might be able to stick it out for the long haul, but FIVE? I'd have bailed after during the 1st day...
bailment = benefit payments cancelled :P
I've been railroaded :down:
FFFFFFFFFFFFFFFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
I'd be bitching to anyone and everyone and demanding they just let me do whatever the assesment is without sitting through a useless 5 week course
You know if you completely cancel your payment, re sign up you start from the beginning again..
I like the way this man thinks
Is anyone here a "computer technician" that can write a report for insurance that my sister fried her laptop by spilling soup all over it?
I have a degree in computer systems engineering, but apparently that does not cut it as I am not a 'technician'.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
