few more hours and it is scotch time
num
Why is it the models on tv look like if they sneezed to hard they would snap in half ?
Women with curves... win :)
Skeletor... out :ermm:
I agree. Skinny bitches just don't do it for me. Bony pointy bits everywhere.
Give me curves anyday :ermm:
P.S. I'm going to bed. You should be able to survive to 7 without me Jase :) we shall speak later about the tools :(
*tips hat*
ooo wait... I have a hat here perfect for tipping
I'm really suprised it took you guys to find that out she made that like 2 or 3 weeks ago. But it was inevitable.
Permission to add as friend?
Bought my new EEE PC today. $475 for one of the new ones with Intel Atom N450 processor, 2gb ram, 250gb hd, windows 7, 6 cell battery n everything. I thought it was a good deal :D Now I can watch porn on the train :)
WinRar!
SCORE! Thanks for the link!!! :P:D:bunny:
+1!! hahaha
NP guys, sharing is caring. Although I was hoping colin would get more pissed off :(. Hate you guys, gooche axing, etc...
LOL! Might fine detective work on facebook martin, even if you are a little slow
Your mum's a little slow
I can has ?
Get in line
I'm leaning towards the nismo shocks..... I wonder if putting my king springs on them would work ok. I'm unsure what springs he has on them now.... hmm...
Grinder love
sticks not that big ... wait for it...
that's what she said
zing
Top form fellas :P
oooo I could totally go a Zinger burger right now... why aren't KFC open? :D
I know hey, where is the 24hr KFC when u need it?
well... brim tipping at least
later pilgrim
secksy
maam
I'm all alone now :):bunny:
I'm scared :D
Don't worry jase, I'm here now. Hugs?
Actually it looks like the Pom is too, three way?
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
