and where exactly are you thinking of at Everton Park?
is there a coldrock/baskins in where that dominos is? across the road from block buster?
+1
which ill let you know marto (as i know you dont go on sd much) is all underway
- should pick up manifold on thursday,
- brake lines getting made up thursday at mine
- steering rack bushings getting picked up this afternoon
:P
I'm hoping to get your wiring done, but at these stage I won't even get to it till friday night probably :bunny:
Priorities have been getting my panels ready to go to the paint shop, as I imagine they'll want them for several days...
Google told me there was a baskins there?
Are you super sure there isnt a baskins there???? I reckon there is ...... lol lol
Well I just drove through there and double checked, and didn't see one. So unless they've managed to throw a cammo net over it...
It seems google lies :bunny:
According to baskins website though, there are also stores at kedron and ashgrove
kedron has eff all parking and a killer driveway. however there is subway, kfc, hungry jacks, and fish and chips there too.
was not aware of ashgrove. where is that one?
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
