and where exactly are you thinking of at Everton Park?
is there a coldrock/baskins in where that dominos is? across the road from block buster?
+1
which ill let you know marto (as i know you dont go on sd much) is all underway
- should pick up manifold on thursday,
- brake lines getting made up thursday at mine
- steering rack bushings getting picked up this afternoon
:P
I'm hoping to get your wiring done, but at these stage I won't even get to it till friday night probably :bunny:
Priorities have been getting my panels ready to go to the paint shop, as I imagine they'll want them for several days...
Google told me there was a baskins there?
Are you super sure there isnt a baskins there???? I reckon there is ...... lol lol
Well I just drove through there and double checked, and didn't see one. So unless they've managed to throw a cammo net over it...
It seems google lies :bunny:
According to baskins website though, there are also stores at kedron and ashgrove
kedron has eff all parking and a killer driveway. however there is subway, kfc, hungry jacks, and fish and chips there too.
was not aware of ashgrove. where is that one?
