no, not really. Because the number of times I've actually driven at the speed limit would be in the thousands. The number of times I've driven over the speed limit wouldn't even be in the triple digits. Remember I drove a cab for years, so lots and lots of good boy driving time to stack up against my handful of indiscretions.
If you loved me more, you'd see me more often. Don't blame me for it :)
I cannot base my assumptions on data I have not seen. :P
what is the speed through it anyway? i thought it was 80, thats enough to make some noise! lol
2nd gear limiter all the way. Then at the end if they pull you over for excessive noise blame toyota and hope they recall some more cars.
I'll even put a playing card on the back wheel for that awesome sound :D
I should do that on mine lol.
Page to the other ranga you mean :(. Colin is the ranga.
Oh and the tunnel limit is 80 normally, but they can lower it at will :D
:P I feel special
1. debatable - pommies don't count as people.
2. "LOOK!!! Imports! Set it to 40 AFTER they enter. Let's fuck up their shit"
Pommie/Strayen/Ranga I count as something goddamit!
ok this is how its gonna go .......
smity is gonna ride a pushie with a stack hat covered with zip ties. of course he will be noticed immediately so thats our que to come through the tunnel and amp up the noise so they get distracted and he can make it through, then we all take a different exit and laugh our asses off!
and if not we all make it on the news .....
Look forward to seeing you on the news :down:
the ranga army is gaining strength ......
Wir musen die juden ausrotten!
They're still no threat: They can't go out in the sunlight :)
True, you got us there ..... :P
We shall assemble our forces and attack with the cover of darkness! RED POWA!
I can't hit limiter in 2nd gear and still be doing 80...
*müssen
To be fair it would have been easier with ratchet spanners, but we didn't have any (Remind me to bring mine this weekend Tristan). But still, next time you are under an RB look how easy those suckers are to get at.
Then theres the culprit heater hoses. Piece of p*ss to get to in an RB, smashed up between the engine and firewall for an SR.
amen! ratchet spanners are win!
ps ppl,
the 180 now has custom brake lines
jealous?!
they is the hot!
off to fulcrum and then engineering place now :P
I keep handing everyone the pages by making the last post on each page!! Dammit!
At this rate, we might make 1000 this year...
+1
LOL!
+1
:D I feel special
You are 'special' :D
Git?
Eich die riesh ver reich...
Red Fail
Sure you can: wheelspin
*müssen
umlaut skillz
jealous?!
they is the hot!
pics or GTFO
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
