hhhhhheeeeeeelllllllllllllooooooooooooooooo!
Its 8.30 am, what u wigga's doing? :D
Been to a bogan swap meet looing for monaro parts, took my stick incase they got to close! Dont know whats going on with the website. :)
just some old pics i just found on a camera, must be from like sep/october 2009
<3 mang. My car looks shiny, this must of been just after I did my uber detail :laugh: oh and sorry I didn't msg you back. All good on the parts shizzle I'll call you in the week to organise something because I'll be going back home for next weekend. :blush:
lol yeh man the car looks epic shiny!
the gun metal 32 is GABNR - but im not a fan of plates on the net, so i blanked it for him hahaha
and yep -we'll sort something out :P
