ohk well i have a z32 AFM chillin' in my room, however bigger injectors + ecu = $$$ fml
alright well i guess ill give old dan a bell and hold my ankles
what ecu does it have now?
And a noun. And a prefix.
Is it in the dictionary yet?
ohk well i have a z32 AFM chillin' in my room, however bigger injectors + ecu = $$ fml
pain mang. Can you use second hand gtr injectors? that would probably save some money.
nah, stock sr ones are almost the same size as gtr anyway! s14 are 440cc and s15 jdm are 480cc
the ecu, which was thought to be stock - turned out to be an aftermarket one of some sort, a japanese dr drift sort of thing - im not sure on its maps etc
Well in that case i wouls assume that tuning is more than likely the culprit, I thought you had it tuned already when i gave my other suggestions, first port of call tuning, injectors to small ect can be tuned around, but i would be concerned for my engine running unknow tuning and experiencing hesitation, what was the cause of the last failure? The ecu could have had somthing to do with that engine dying too
yeh - the guys who sorted out the timing discovered the ecu. the dyno run to sort out timing was included when i bought the new motor - so no "tuning" went on
alright well ill turn the boost down in the mean time and try and get it on the dyno
sounds like a solid plan!
Might as well chuck on the z32 (just)before the tune too
PS! JOHN!
did i see you post a link to "secretdick" on the last page?!?!
WOOOAH
you've changed man, but im not complaining ;)
Indeed. I'm like an epic classifieds lurker these days :)
Or a pimp 33 4 door...
mmmmmmm rolling sechs
Tristan you should talk to Dan at ERD, he is pretty sick at over the phone diagnostics, just dont take too much of his time cause i want him to finish my engine :P
I really have to remember to call him about an attesa filter one of these days
someone just replied saying AFR should be checked out and therefore needs dyno time
he also said 1 bar is too high on stock injectors/afm
ugh GAY
Thought you had a Z32 AFM? That'll easily hold 1 bar mang
He has some experience with SR's, he is the RB guru but very good with SR's too
but if he suspects it is sensor or elec problems he will likely send you to EFI, which will make you cry, because they have an ocilliscope and he doesnt
Going to EFI would even make baby Jesus cry
Oh, I have a "thought to be stock" car too, but it just keep throwing me goodies and surprises! I want to check my ecu, and do a dyno run. Just to see what's really inside it.
ah the joys of my car :(
+1 for every other bastard in this thread
This 'splains Z32ness
yeah... in your room will help. Now you can run like 2 bar through your desk. Win.
Put it in the damn car and get it tuned :)
PS don't remember seeing it - but did anyone say fuel pump? Is that still an old one? Or has it been replaced?
PPS there was like... one whole page just about dongs. Not a bad whoring effort, I must say.
yeeh john i have a z32, but i didnt fit it up - guess now im going to have to hahaha
joy!
Fit it and run it and see how it goes. Might go ok, might drive like a bag of shit and need a tune, but you might be lucky and it'll just run.
yeh bad idea - itll run like a total ballsack ive read
and yeeh i have a new fuel pump
and yeh my desk runs wicked boost and flutterz hektikly :)
aww really? :) that sucks. I was hoping he might fluke it
It *MIGHT* be OK for just babying it around for a bit, although its highly unlikely.
Is DEFINITELY a bad idea for driving it hard/pinging of limiter for drift. The mixtures are going to be wrong, and most likely they will be lean. Turbo engine + lean = splode
hmm... this is very true.
damn... well... get it fitted and tuned son!!
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
