Sarp Dan. I'm chilling at Baskins. Jailbait isn't too bad tonight. Not as epic as last week but decent. Fockers come and keep me company lol
If I point to the ice cream I want, I can give them a sneak peak of the gun show :cheers:
Ah so that's where i'm going wrong. A. can't show the guns and B. cold boys.
Your so informative
Ahh, you buggers nicked off early.. I just drove around to BR!
We pretty much leave at 10 these days as colon has to get the train
I've got a note from your mum, does that count? :)
oh snap :laugh:
I had to show you how to do it right and how not to do it :P
That's what she your mum said
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
