Its boring at work at the moment. 5pm now and I've got to hang around for another 2 hrs probably =/
Still haven't managed to hit my boss over here for a ride... I only found out yesterday that he's got a 35 gtr.
edit: page.
Edited by GTTG
edit: page.
How long you working there for ?
Yeah they're brutal+fun..... together..... at last..... hahahaha
If you're not already into Parkway Drive, do it. "Killing with a smile" is definately my fave of their two... with a new one coming out soon.
Carpathian - Nothing to lose (might have trouble finding online but i can burn/rip you my cd)
Bury your dead - beauty and the breakdown (think I said that one before)
Bleeding through - the truth...... f**k I love this album so much, I'm gonna put it on right now hahahaha
The new Parkway Drive song - Sleepwalker
Had the pleasure of sharing the stage with them a few years back along with IKTPQ.
Bury Your Dead, not sure whether I like them or not. Sure, they've got some great songs but it seems everything they've done has lacked something.
I'm not sure if you're into the more hardcore stuff but I've recently discovered Sea of Treachery.
I feel I'm inclined to recommend this song to everyone I know because it's still got to be one of my favourites over the past few.
Now, it might seem pretty brutal to begin with, but just listen to the entire thing, it's worth it.
Between the Buried and Me - Mordecai
I'm over here for another 5 weeks still :sick:
dunno what I'm gonna do tonight... going out and getting pissed in some pub by myself doesn't sound that appealing (kinda sad, really).
Not the first time we've taken up pages with out midnight chatter :sick:
Hylian - thanks for the other suggestions. I'll look into them shortly :action-smiley-069:
Yeah true true. I think it is also expected from us :) Gives the rest of the crew something to do / look forward to in the morning
Yeah true true. I think it is also expected from us :action-smiley-069: Gives the rest of the crew something to do / look forward to in the morning
True. Tim will appreciate having something to read when he gets to work :sick:
I think he's secretly starting to like his new name. Tim and Dan brought me dinner thursday. :action-smiley-069: I showed them the zombie proof control center.
Actually - I just realised that it's Saturday, and he won't be at work. It'll give him something to read with breakfast instead :action-smiley-069:
Come in tonight just let me know what time. I'll show you around. :sick::)
I'm babysitting my nephew tonight. Well, sitting him in front of the Wii. But still...
He and Becca should have a playdate :action-smiley-069:
He and Becca should have a playdate :sick:
That would be cool. Next time I have her I'll let you know. You can come and have a look around anytime but it has to be either on a afternoon 3-11 or a late 11-7.
