HAHAHAHA JOHN
You're just pure win at playing facebook the last couple of days aren't you?
ahhhh I try :)
and now after the last page of this thread I'm going to go and be violently ill. As if destroying one thread wasn't enough >.<
Why isn't the alfa in your sidebar?
Lazy. Might just get rid of all of it :P
and did you even see the picture I left you?
I did. Made me cry because mine doesn't move :'(
not THAT side bar :P
yeah, bad idea to edit your PI when in a lazy half-assed mood. I updated my sig though, so it's getting there :P
It looked pretty hot. I touched myself for a while before I thought to get a photo for you.
Edited by Isola
you could fap
Not a bad idea...
hey mangs
The problem with public fapping is.,.....ah, the problem .... ah.... no tissues??
The fines?
Go hang at baskins all day? I'm sure if you're there for that long you can manage to hook up with at least one of them :P
Thats what it sounds like to me.
If you're not making a mess, you're doing it wrong...
Hmmm I don't think my laptop batteries would last that long.
Exam done btw. I dunno what to make of it. It was a piece of piss and I was one of the few that finished it :S I either did a lot wrong or I am awesome. I think it's the latter tbh.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
