I've never understood this economy thing... My R33 is dead stock, 1993 so it can't be the "1.5" version, backfires on every gear change (practically) so its gotta be running rich, but I still get 440kms CITY driving, 580-600kms country driving (180kms flogging it!)
That's filling up just over 50 litres (BP Ultimate). What are people doing to get these 250-300km/tank figures?? Or is it more a case of "boost addiction"??
Lol,
I dont know about r33, but mine getting around 350-400 km fuel tank.
Is there something wrong? I use normal boost
Anyone got any idea? please help
but last time at dyno, My car showing rich fuel it still giving me 350 km pert full tank so i guess my stock r34 need fuel controller
