Hey guys
Selling a set of Starcorp Impuls deep dish in white. Specs as below -
3/4 have gutter rash. Front wheels are 8.5" and rears are 9.5".Tyres have legal tread on them, tyres are Kuhmo Ecsta SPT's 235/40R18 front 265/35R18 rear.
One of the rims is bucked with some speeling on the lip as per pic -
Because of the buckled wheel im selling the whole set for $500
SYD pickup only.
Thanks
