hi need an rb25det manual transmission/ alternator harness and the peice with the knock sensor plugs on it
pm me.
cheers
hi mate got an rd25 box with OS giken crossmission gear set 1st to 4th in it ,with pivot shotshifter included
$2500 might take less with trade manual/auto
and i might be able to find the harness part your after got a lot of stuff lying around?
0421809652 cheers mate
