Sard 700cc injectors (second hand) $680 delivered
PFC D-DETRO with harness and map sensors (second hand), no hc !(to suit 34 gtr) $980 delivered
Exedy carbon twin plate clutch second hand needs rebuild ! $250 plus delivery
Apexi boost controller (brand new) $480 delivered
R34 GT-R tail lights $375 delivered
https://www.sau.com.au/forums/topic/270058-gt-r-stuff/
STILL FOR SALE , PFC D-JETRO , BRAND NEW APEXI BOOST CONTROLLER , BRAND NEW NISMO RODS , CARBON EXEDY TWIN PLATE CLUTCH , 34 GT-R TAIL LIGHTS .
Also have some second hand nismo castor rods for 33 gt-r $100 pick up
https://www.sau.com.au/forums/topic/270058-gt-r-stuff/#findComment-4619403
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
