hey i know i have only had the car for a lil while but im really pushing to make club outrun(my clothing label) big so i need more money to put into it so im going to down grade cars for a while and put more into the busness
i love the lozza but cash could be better used for me atm
looking for 13k
its a 1993 nissan laurel 2 tone white pearl over gold
has ams coustom front mount and piping
s2 rb25 engine and box
twin plate clutch....... effing mint
1 peice tail shaft
full turbo back zorst with tuff twin pipes really neat note
welded diff but comes with a 2 way that just needs new bearings
strut braces front and rear
lock spacers
camber arms rear
5 stud rear and 4 to 5 stud spacers front
works rezax 3 peice meshies 17x8 and 9 good tyres all round
catch can
emanage ultimate tuned by status for a safe 180 rwkws on 11psi meaty tourqe
nardi wheel
pair of bride seats really low mounted
1 blitz water temp gauge
1 greddy boost gauge
15cm blue dildo gearnob mounted on shortened gearstick so it sits at a nice height
HSD coilovers fully adjustable mint ride and awsome for hard driving aswell
interior pretty mint
car in general in really good condition
few lil car parking style nicks here and there but really mint for 93
oh it comes with a jaf badge on the grill
thats all i can think of at the moment
looking for $13000 rwc incl
car is well looked after frequent oil changes
yes i could have vacumed it before interior pics sorry lol
price is pretty firm
call me on 0413449246 thanks
reg fink
not even a peep on here nissansilvia peoples going crazy for it skyline aus nothing..... i thought it would be the other way around
i wish mine was reg'd... and had a 25 in it!
good luck with the sale man... if i sell mine quick enough i'll buy for sure!
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
