The one I had checked was Black with aftermarket front grille and chrome SSR professor copy wheels (despite them saying they were genuine Work wheels).
I had also decided I would get the Candy Blue one with CE28Ns and front lip checked, but they sold it on me. Then a stocker Red one with sunroof, but they sold that as well!But that was before I did all the extra homework and found out just how much of a bullet I dodged.
Word is they have plenty of vehicle check guys in their pocket, so beware.
  • Replies 45
let hope the MTA guy i asked was legit....but i think the 3 year warranty should be enough to cover for the car...
mine only had 28,000 on the clock... the inspector did said the car was in very good condition.. apart form some little stone chips on the front
  • 10 months later...
Why don't you import yourself from an auction?
then you will have auctions sheet, hopefully Log book and spare keys!!!
all you have to do is convert Fm
hey is it possible to give me a link or addy to auction skylines
Thumbs up for Japlink Motors at Haberfield... they definately gave me the best deal for my V35 and also the service was great.
Have had one problem on the car and they fixed it straight away and threw in a courtesy car so I can get to work.
Have had the car for 10 months now and the cars going great.
As for the warranty, with any dealership or salespeson you should always read it properly. Take it home and read it even. How much you're paying for it versus how much it covers and conditions of the coverage. I was with All States Warranty way back and I reckon they were the best. Don't know if they still exist though...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
