Hey everyone,
OK, I dont have a Skyline but im a guest over from perth falcons. An Intruder if you like :dry:
I've heard from a good friend that out on your cruises, you've been to the infamous truck stop off of Albany Hwy and that you have had to deal with that menacing bloke in the big ute that comes to ruin your cruise.
Its happened to me and some mates (not on a falcon cruise) twice now out of the 3 times we've been there, and frankly its pissing us off.
Does anyone know who this bloke is??? What his problem is and why??
What gives him the right to break up a car meet? Does he own the area or something?
He lives across the road and you will find he s the owner of the truckstop so you people are trespassing on his property so now you know why he gets pissed off
.... so now you know why he gets pissed off
Yes I do...but this is funnier
"All you teenagers GTFO...mmm that reminds me of the time we went over to shelbyville during the war, I wore an onion on my belt....which was the style at the time...you couldnt get those white ones, you could only get those big yellow ones.................now where was I........oh yeah, the important thing was I was wearing an onion on my belt, which was the style at the time, you couldn't get those... (trails off)"
    • I tried the next one up from 600k ohms which is 60M on my multimeter and all readings came out as 0.00 ohms so right now the most accurate is 600k ohms with only a 0.1 ohms difference between coils. Three coils read 1.4 ohms and the other three read 1.5 ohms.
    • surely that is a control arm, not a sway bar. In any case, visual condition should not be an issue, excessive movement under load (eg with a big pry bar) would be the issue. I can't see 99.999% of pink slip places even looking, let alone trying to test it
    • I attached the image of the only thing I found, nothing to do with ohms in the manual only torque values etc. However, being they are so close to each other I am almost certain they are good. Tomorrow I will test the spark plugs while I am there. and look at the ECU connections.
    • Hi Gents. Do u know what 18rim will fit under R32 GTST with no modification of current setup I have. I have buddy Club P1 17x8 on front and 17x9 rears and they fit well.   Will an 18x9 on 35 off set with 235 tyres up front fit? ON the Rears i can run the rim size n fit 255 or 245? or i got option to get 18x9.5 on 35+ Offset n 265?   CHeers
    • And, when measuring and getting <2 ohms, perhaps chose the next larger range than that, rather than something with a k in it!
