is there anyone out there in this wonderful world that might have access to a genuine S1 alloy bonnet, grille, or front bar?
crash repairer is having a hard time trying to find part numbers for these items.
anyone with FAST????
This might be no help
This is a pic of a series 2 front bar REO part number
correction:
now only need Genuine Autech Grille and Front Bar (series 1)
hey i got a mate who got an autech front cut the bar is messed up but the grill still good ill find out price and let you know
Edited by 260rsstagea
nigel,that s1 front bar is still available,and i dont think its going anywhere in a hurry.its not genuine but so what.aleks rang you about it today.let him or me know and we'll pass on the dudes details
I have my old S1 genuine front bar for sale, it has a bit of a crack in the lower lip and needs a bit of repair, but only want $350 for it.
ill shoot you some pics if your interested.
Cheers
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
