Hey guys,
I have some S15 stuff for sale. They were on my S15 before being upgraded. All items came off on or before 75,000 km's
S15 Bilstein Shocks and springs. Good condition. Suspension is harder than OEM, but still decent enough to be on a daily driver car. It comes with no strut tops. You have to use your existing ones. Dust boots and bump stops are included. They give the car around 340mm center of wheel-top of wheel arch ride height. See last pic. Asking $750 for these
Excuse the dirt in some of the pictures. I've tried cleaning them as best I can, but some grime seems to have stuck on pretty good and i couldn't get it off just with a sponge and soapy water.
480cc injectors. They are the stock turbo manual injectors. They came off a JDM S15, but from what I've told they're identical to ADM ones. $250 for these.
S15 Stock fuel pump. Again, off JDM S15, but same as ADM model. $50
Clear/chrome/altezza/whatever style tail lights. Good condition. No scratches or anything. I just took them off cause I don't like the way they look. Asking $150
Stock airbox. No snorkel. Comes with K&N High flow panel filter. Filter seems to be in good condition. Also, box comes with ultra-hektik K&N sticker. Guaranteed to pull da chickz!!1** $50
I also have some stock R33 stuff still for sale. See http://www.skylinesaustralia.com/forums/R3...xi-t265485.html
**PLEASE NOTE: It has been scientifically proven the K&N sticker will not actually pull chickz.
Edited by Goosy
  • 3 weeks later...
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
