Subaru Impreza, WRX
MY-06, 5 Speed manual
Rally blue
70,000ks
Aftermarket STI cooler
Enkie SC16's 90" tread all round
Koni lowered suspension and springs
3.5" AFtermarket Stainless exhaust system turbo back
Factory exhaust goes with car in boot
Pioneer deck, cazzazeria amps under both seats
Aftermarket air intake kit no pod or filter
STI rear spoiler
Clear tail lights
xenon headlights fitted crystal
Tinted windows
Subaru books in car, service history!
Car in south Australia can be registered in either states, freight can be incorperated into the price. Any mechanical inspections welcome car runs A1. Paint and body immaculate.
Call 0431 388 718 any questions $ 26, 990 (negoitable) Make an offer most conisdered!
Edited by sus34
ok rephrased for people,
The car has an aftermarket intake system , sold by S and J , it has a k n panel filter,
The cooler is a Cooling pro aftermarket alloy cooler with STI on the top ( better than sti)
The wheels are SC18 enkei's 18x8 +40 with new tires
The exhaust is a 3" stainless Turbo back, with hgh flow cat,
The amps are pioneer carotezza,
ALso has a very rare carbon fibre Rear window splitter,
And an STI alloy bonnet ,
This car is a good all round car, goes good and the fuel ecconomy is sweet too ,
Good luck with the sale simon
yeah it sucks his not in NSW
what sort of fuel economy do you get??
Highway k's from a full tank is max 520, hills and city driving around 450ks. Car can be freighted to any state in aus for a cost quite happy to help as the car must go for interested parties.
Edited by sus34
Is it an actual STi manifold or have you hand painted the standard manifold gloss red? After you put the exhaust on have you had the ecu dyno tuned to suit?
Thanks.
Its sprayed red not an actual STi manifold, exhaust was put on buy previous owner and was tuned so runs mint.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
