Hey Guys,
ALL of these wheels are in stock
Volk GT-C- excellent condition
114.3x5
18x9 +25/30 (80mm/61mm dish)
Tyres 235/40 ~65%
$2800
Volk GT-7
18x8.5 +? 114.3x5
18x10 +? 114.3x5
$2700
Genuine Black Volk TE37
114.3x5
19x9.5 +22
Toyo 245/35/19 ~70%
$4400
Volk 57F Pro Noble Gold
18x8 +24 18x9 +24 225/40 GIII ~75% Rear Bald $2800
Work CR Kai
18x8.5 +32 18x9.5 +38
Advan S Drive 245/45 275/40 ~70% $2700
SSR SP1 Pair
114.3x5
18x10 +16
Tyres Not included
$1400
Work Meister S1 2P-Gold
17x8 +35(60mm dish)
17x9 +20(65mm dish) $2400
Volk GT-V 18x8 +33 (55mm dish) 18x9 +37 (75mm dish) Falken 225/40 ~90% $3000
Work Seeker CS 18x9.5 +15 18x10 +15 245/45 265/45 ~70% $2600
Volk Racing GT-AV Chrome 19x8.5 +23 (50mm Dish) 19x9.5 +24 (83mm Dish) Toyo 225/35 ~70% Bridgestone 255/30 ~50% $3900
Volk GT-C top secret gold PAIR of 18x9 +25$1500
Volk GT-C Face 2-Top Secret Gold 18x9+37(55mm dish) 18x10 +30(73mm dish) $2900
Work VS-KF Chrome 19x8 +9 (66mm dish) 19x9 +7 (104mm dish)
Tyres not included $3300
SSR SP1 - Excellent Condition
17x8 +27
17x9 +37
DNA 235/45 255/40 ~50%
$2550
Work VS
114.3x4/5
17x8 +22 17x9 +22
Bridgestone 225/45 255/40 ~60% $1550
Work CR Kai White 18x8.5 +30 18x9.5 +30
245/40 Yokohama DNA ~60% 275/40 Potenza G3 ~60% $2500
Volk GT-C Sparkling silver Face2 18x9 -1 (80mm dish) 18x10 +19 (93mm dish) $3700
Federal tyres ~60%
Volk GT-N Gold-In very good condition 18x8 +22 56mm dish 18x9 +25 88mm dish
$2450
Work VSKF-Silver 18x8 +26 18x9 +33 $2300
Volk TE37- Chrome-Limited edition 19x8.5 +22 19x9.5 +22 245/35 ~60% 275/35 ~60% $4400 TE37Chrome_small.jpg
SSR SP1 Professor 17x8 +27 17x9 +24 Tyres 215/45/ ~75% Yokohama $2400
Work CR Kai MHG Bronze-Brand new 18x9.5 +12 PAIR $1400
Nismo LM GT4 Silver 18x8.5 +25 18x9.5 +30 Yokohama 245/40 275/40 ~55-60% $3400
Volk RE30 18x8.5 +25, 18x9.5 +35. Advan S Drive 245/40, 275/40 ~95% $3500
Volk GT-7 18x8 +36, 18x9 +39. 235/40/ 265/35 ~60% Dunlop $2500
Work Meister S1 18x8 +38 Toyo 225/40 ~75% 18x9 +38 Potenza 245/45 ~75%
$2700
Work Meister S2R 18x8 +35, 18x9 +35 $1250
Black Racing N1 Pro 18x8 +30, 18x9 +38 $2100
Note: PRICES ARE FOR PICKUP IN MELBOURNE. INTERSTATES WILL BE LITTLE EXTRA
For more info on the wheels or anything you find on the website please email at [email protected] PM or call 0422 422 344. :thumbsup:
Thank you
Regards,
Thuy
  • 1 month later...
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
