1998 Nissan Skyline R34 GT-T Coupe (Black). 120,000KM. Stock.
First Australian owner – Imported in October 2008 at 110,000 KM – Grade 4 out of 5 Import.
Car is completely roadworthy and hasn't been modified since inspection. Registered until November 2009. Moved from the ACT recently.
High quality wheels, 4 speaker sound system, brand new Alpine CD player & full immobilizer with alarm system. Very well looked after, always garaged and always driven appropriately.
Car runs beautifully and has just been serviced. Full manual and service history available. $16,900 ONO. Low price for quick sale. Inspections and test drives welcome.
Call or SMS (if i'm unable to pick up) 0434 214 542
Contact Details
E-mail: [email protected]
Mobile: 0434 214 542
Edited by snoopy4eva
https://www.sau.com.au/forums/topic/280084-skyline-r34-gt-t-16900-ono/
Apologies all I used the wrong price for whole add. Stupid copy and past mistake from my first draft.
Price is $17,500 ONO. As stated it's 5 Speed Manual
  • 1 year later...
hey mate, if ur interested in swapping i have a vk group 3 repllica, very clean car, worked 308 engine probly done less than 15000kms, very clean engine, i have car listed on here to look at, have a look and let me no, cheers, 0421175527
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
