Originally posted by BY BY
Gerds,
I can get a you nice set of Advan copies for you which do fit a skylines offset. They are available in silver, chrome or black shadow chrome.
pm me for info
Available in 17's,18's or 19's
Nick
Would the 18's or 19's fit a 33 GTST? how much do you think this would come up to with tyres?
https://www.sau.com.au/forums/topic/2811-roh-shadow-chromes/#findComment-50093
25GTT: yeah 18's and 19's will fit. 19's particularly will depend on how low your car is and what width rim you get.
I have seen a white R33 with 19 inch bronze versions of these advans as seen below and it looked wild
http://www.nismo.com.au/morepics%203/advan.jpg
I think 19's with rubber are around $3500
I would expect the 18's with rubber you'd be looking around $2600
https://www.sau.com.au/forums/topic/2811-roh-shadow-chromes/#findComment-50106
Gerds,
I have a set of ROH Adrenelin Shadow Chrome's on my R33. When I emailed ROH for a set of lock nuts they told me they don't make those mags to fit skylines. But Bob jane showed me the catalogue for the lock nuts which listed R33 GTS25t as a model and the nuts fit perfectly.... Weird.
I'm not sure of the offset cause they came with the car.
Here's a pic..
https://www.sau.com.au/forums/topic/2811-roh-shadow-chromes/#findComment-50243
By BY: Cheers dude, but I'm looking at the blitz rims in the for sale section and drooling atm.....
Gerds,
I got the rims with the car, they are 17's, I think they are 8"s all round. My brother in law is looking at a set of 16's for his lancer and BJanes quoted $340 per rim for them, so I'm thinking 17's would be around the $400 mark??
https://www.sau.com.au/forums/topic/2811-roh-shadow-chromes/#findComment-50614
Guest Crazyfcuk
ive got the same mags as evl r33 on my line (and number plate - not on purpose). Mines a na tho, not sure if its any different.
go to www.cardomain.com/id/crazyfcuk theres a photo of them there.
They are quite narrow tho, mine are 18x7 tried to get 18x8 but they were sold out and not getting anymore in.
i paid 3000 for mine with kumho tires
https://www.sau.com.au/forums/topic/2811-roh-shadow-chromes/#findComment-51589
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
